sign of a bad injector
Old Jan 5, 2009 | 01:25 PM
bigty's Avatar
bigty
Default sign of a bad injector
What are the telltale signs of a bad injector????? My truck just feels like it looses power sometimes, and it's like I have no more pedal.
2006 MegaCab 3500 4x4
Air Intake
AFE Intake Manifold
Superchips Flashpaq Tuner
4" Bully Dog Exhaust
Aero Turbine in place of the Cat.
45,000 miles
Thanks for any help
Ty
Old Jan 5, 2009 | 10:12 PM
Parts/Service's Avatar
Parts/Service
Running rough, skipping, hammering, knocking.....All signs...
Old Jan 6, 2009 | 01:15 AM
SpLaT's Avatar
SpLaT
Like Parts said, you can also check with a "raytech" lasor temp gun (get at any good auto parts store) after the engine has been warmed up take for a spin then pull over pop hood and shoot each exhaust port (as soon and safely as possible), if you find an injector or more colder or hotter then the rest you may want to have them looked at. (temp differences of around 50 to 100deg denote issues)
injectors that are cold may be carboned up...cause would be excessive idling, or a pressure box/programmer adding too much fuel.
injectors that are hotter then others... excessive fuel
excessive fuel can leak down the cylinders when engine is cold... you might want to check engine oil level, if your gaining/making extra oil (pull dipstick sniff oil .... check for diesel smell) you may have an injector or more leaking fuel (injector tubes can also leak causing extra engine oil)
Old Jan 6, 2009 | 06:07 AM
bigty's Avatar
bigty
Thanks for the reply, I'll try the temp gun method first.
Ty
