transmission service ? (60,000 miles AT)
Old Jan 13, 2009 | 11:35 AM
Jesse James's Avatar
Jesse James
Default transmission service ? (60,000 miles AT)
I have a question with the 60,000 mile service for a AT transmission, I have a 2005 5.9L 4-speed auto. It says to refill AT and replace the filter for the trany, I have talked to othere that have the same and said they have never changed there AT trans fluid or filter becouse its a sealed trans, and then others that have said it is a must. I guess my trans is the 48RE, correct me if im wrong, so my question is do I change the trans fluid and filter or not.
Old Jan 13, 2009 | 06:06 PM
Bass Hunter's Avatar
Bass Hunter
Definately change it. Get the old dirty fluid out and some fresh in. It's a very easy do it yourself project.
Old Jan 13, 2009 | 11:26 PM
Parts/Service's Avatar
Parts/Service
You have 2 choices.
1) never change it and be mad when it dies.
2) change it. Would you not change your engine oil. Why does Dodge recommend changing it if its not required....
Old Jan 14, 2009 | 06:55 AM
Jesse James
Default True True
True true its as good as changed,
