dropped valve with bad head damage.????
Old Mar 16, 2009 | 07:46 AM
salbendidi's Avatar
salbendidi
Question dropped valve with bad head damage.????
hey guys, i have a early 04 dodge cummins 3500, i dropped a valve seat, to make this short the head is a boat anchor now!! what i wanted to know is if a 325 hp head would work on a 305 hp motor?? maybe with a little mod?? is that whay seperates the one engine from the other is the head? from what i have seen so far the 325hp head has better valves/seats and better air flow. will she work?? regards, matt
Old Mar 16, 2009 | 09:28 AM
Coal Train's Avatar
Coal Train
Same exact head.
The difference in the 305 and 325 is programming and slightly different cam profile.
Otherwise, it's identical.
Old Mar 17, 2009 | 03:20 AM
steve05ram360's Avatar
steve05ram360
why cant you fix the head?
Old Mar 18, 2009 | 03:21 AM
salbendidi's Avatar
salbendidi
where the seat bottoms out in the head is all broken out. so the seat would have nothing to back to. and at that, would have no support.
Old Mar 19, 2009 | 07:24 PM
salbendidi's Avatar
salbendidi
Question
hey guys i have the casting number off a 2004 head. i just wanna know what it means as its diffrent from mine! its ..... 3965999.
Old Mar 20, 2009 | 02:22 AM
rabbler's Avatar
rabbler
Did the connecting rod bend too?
Old Mar 20, 2009 | 05:37 PM
Coal Train's Avatar
Coal Train
You won't bend a connecting rod on a valve strike in a Cummins.
The stock internals are so overly built it's rediculous.
The stock components in a Cummins don't have issues until you are up near the 1000 HP mark.
It's seriously retarded how stout the bottom end of these engines are.
The weakest link in the entire 5.9 long block is the valve springs. Switch those out and stud the heads and you are good for everything except a full on race engine.
I routinely push mine with 60 - 72 psi and it doesn't even break a sweat.
