whats this issue?
Old Mar 23, 2009 | 09:27 PM
blacksmoke's Avatar
blacksmoke
Default whats this issue?
2007 1 ton dually 4x4 power steering has a funny wobble feel to it from time to time. What might this be? Dodge thinks it might be the power steering stablizer? Suggestions? thanks for the input
Old Mar 28, 2009 | 07:13 PM
SOUTHERN SMOKE's Avatar
SOUTHERN SMOKE
sounds like the notorious death wobble to me, some people expierence it, some dont, but its because of the cheap weak stabalizers dodge put up front in their trucks....
Old Mar 29, 2009 | 09:01 PM
Parts/Service's Avatar
Parts/Service
Here's a TSB that is supposed to upgrade the front steering components to the newer beefier 08 style (includes the tie rod ends)
TSB #22-005-06
Models:
2003-2007 (DR/DH/D1/DC) Ram Truck (2500/3500)
NOTE: This bulletin applies to four wheel drive (4x4) 2500 and 3500 model vehicles.
Symptom/Condition:
The customer may experience a self sustaining vibration (shimmy) felt in the front end of the vehicle after striking a bump or pothole.
Parts Required:
52122362AE---Updated Steering assy (Rev E) Make sure you get Rev E, there's a recall on earlier ones.
68039930AA---Updated Pitman Arm
52122370AB---Steering Damper
6502473---Bolt (1), to attach steering damper
6505623AA---Nuts (3), to attach new linkage
6502835---Nuts (2), to attach steering damper
Old Apr 21, 2009 | 01:26 PM
soobad's Avatar
soobad
Default death wobble
yes i have the death wobble also and it almost held up to its name the other day, driving down the highway a ford wanted to have a show of power so i dialed up to level 5 on the chip and busted his nadds when i hit about 115 mph but then i must of hit a wripple in the road and the truck started jumping, i thought the fenders and hood was coming off the truck, the truck has done this to me several times and i have rotated tired, new shocks, bought new tires and had the alignment checked, but now i'm reading on different websites that dodge may have a problem with front axle some people are saying the axle is in a twist and when you have the alignment performed they are setting to dodge specs and others are saying they are not right and it needs to be twicked a little...sorry long winded
