Aux. Oil Cooler
Old Apr 4, 2009 | 09:53 PM
High_On_Diesel's Avatar
High_On_Diesel
Default Aux. Oil Cooler
Have been thinkning...scary...I know...but...seeing how there is issues with turbos coking and what not...has anyone installed or thought about installing an aux oil cooler? I have a new fuel cooler off of a Liebherr crane that is up to the task, jus dont know if it would be beneficial to install.
Old Apr 4, 2009 | 10:53 PM
rabbler's Avatar
rabbler
You already have an oil cooler built into the factory oil filter housing.
Look closely and you will see the oil feed to the turbo is right off the oil filter housing, so your turbo is getting pretty cool oil already.
The best thing to to do to avoid coking is let your engine idle 1-5 minutes before shutting it off.
Old Apr 5, 2009 | 07:23 AM
09W3500's Avatar
09W3500
That's what I do.
Old Apr 5, 2009 | 09:22 AM
racer9's Avatar
racer9
The "coking" is not caused by high oil temp, it's caused by a high turbo temp. Think of it as pouring cold oil into a hot frying pan, that's what happens. The turbo is what needs cooled, specifically the exhaust side.
Old Apr 5, 2009 | 11:35 AM
High_On_Diesel
10-4 guys! That works for me! Thanks for the info...
