Ball Joint day!
Old Apr 6, 2009 | 04:08 PM
steve05ram360's Avatar
steve05ram360
Default Ball Joint day!
Well today is the day I start tearing it down to swap the ball joints. Will be stopping by the tool store to get the ball joint press and adapters. I read that the whole job for 1 side can take as little as 3 hours so I'm going to put that to the test. I plan to take plenty of pics for a DIY writeup so that will slow me down some.
Carli Suspension uppers $550/pair from Carli themselves
Moog lowers $140/pair from RockAuto.com.
should be fun...
Old Apr 6, 2009 | 05:13 PM
2005RAM2500's Avatar
2005RAM2500
Nice choise on joints, i went with Moog upper and lower. Good luck it took me alot longer then 3 hours but it was my first time.
Old Apr 6, 2009 | 05:23 PM
steve05ram360
thanks, it's already looking like I wont be able to start until tomorrow... have 2 stops to make, 1 for tools and the 2nd is for a friend... helping him to find a CTD of his own. Found one that should be what he's after but he's out of town and wont be back till Wed. Asked if I could have a peek at it on my way home.
What made it take so long when you did your install? (I mentioned 3 hours/side for about 6 hours total...) I figure I could get to pulling the hub in about 30 minutes or so. I expect that to be a b!tch for sure. As long as the tools dont cause a problem, 3 hours for 1 side should be enough... If I can get one side done at a time, it'll leave my weekend free :-)
Old Apr 6, 2009 | 05:36 PM
2005RAM2500
I miss read your first post thought 3 hours total.
Just under 6 hour sounds right for when i did mine ran into some very stuborn bolts had to use breaker bar and pipe to get them to loosen up.
Old Apr 6, 2009 | 05:56 PM
steve05ram360
cool... I have a good impact wrench for the axle nut and have various tools & methods to remove any stubborn bolts. I am going to attempt to press out the hub from the back using a bar on the bolts & the power steering unit. slowly & carefully. hopefully it'll work ok.
how did you get yours out?
Old Apr 6, 2009 | 06:49 PM
NickBeek's Avatar
NickBeek
Steve, when the tech at my dealer replaced my front bearings my hubs were not rusted in like a lot of people talk about. He loosened all the bolts and gave them a tap from behind and they popped right out. My truck has lived it's life in SC where we don't use a lot of salt on the roads. If your situation is similar, you may not have a big issue with the hubs either.
Old Apr 6, 2009 | 07:33 PM
steve05ram360
That would be awesome. I dont think my trucks ever seen salt on the roads... sand yes, salt, dont think so.... It's been a Cali truck it's whole life.
Old Apr 7, 2009 | 11:31 AM
steve05ram360
no progress made... I did get all of the tools I think I need though.
Old Apr 8, 2009 | 01:40 AM
steve05ram360
well I got it torn down to the point where the ball joints are ready to come out. turns out I do not have the right adapters to press them out so I'm stuck. Took about 75~90 minutes to get down to the joints...
Old Apr 8, 2009 | 10:54 AM
2005RAM2500
http: // http://www.harborfreight.com/cpi/cta...emnumber=46389
This adapter set should work.
