real bad rattle
Old Apr 14, 2009 | 08:26 PM
jstalnaker70's Avatar
jstalnaker70
Default real bad rattle
i have a 04 dodge. when it is sitting there idaling it has a real bad rattle. but if you put a load on the motor like going down the road it goes away. i took it to the shop today but my guess is that its the rail pressure sensor. does anyone else have any ideas.
Old Apr 15, 2009 | 12:04 AM
rabbler's Avatar
rabbler
Any codes?
If the FCA (pressure regulator on pump) goes bad it can default to wide open and cause the rail pressure to be too high (23,000 psi)
That will cause a bad rattle at idle.
FCA's are real common to fail.
Old Apr 15, 2009 | 03:28 PM
jstalnaker70
narrowed it down to either the regulator or the rail sensor
Old Apr 15, 2009 | 04:04 PM
rabbler's Avatar
rabbler
With the key ON engine OFF does the rail pressure sensor still read very high pressure?
If so I would suspect the rail sensor.
Old Apr 17, 2009 | 10:02 AM
D's Ram's Avatar
D's Ram
any word yet, mine has a noticible rattle at idle also. I was thinking to just check if the valves were out of spec. How would you check the rail pressure sensor? I don't have any engine codes.
Old Apr 18, 2009 | 06:31 AM
jstalnaker70
good news i found it. bad news it was the fca (pressure regulator) those little things are exspensive. dodge sure are proud of those things. but it is fixed now and running good thanks guys
Old Apr 18, 2009 | 10:50 PM
rabbler's Avatar
rabbler
Thumbs up
It's Bosch part, that's why it so pricey.
You're lucky you can buy the part separately. For the first few years you had to buy the whole CP3 pump to get the regulator! $$$$.$$
Glad you got it fixed!
