97 throttle rod problem
Old May 17, 2009 | 02:00 AM
Tally12V's Avatar
Tally12V
Default 97 throttle rod problem
OK, so I finally got around to adjusting my idle and TPS sensor. After determining that it needed to be adjusted (was only showing .4 volts instead of 1.0 ish) I proceeded to
1. accidentally detach the throttle control rod
and
2. break off one of the ends.
temporarily I rigged the rod up so it might possibly work, but I cant get it back on! Anyone know if there is a trick to this?? I see there is a flat spot on the round throttle stud, but I have been at it for over an hour with no luck.
Tomorrow I will hopefully be able to get or locate a replacement through dodge, but I will still have the issue or attaching it...
It cant really be just that difficult, can it??
Old May 17, 2009 | 05:31 PM
estrada5.9's Avatar
estrada5.9
All you have to do is just force it on it will go. The rod has to be the same length as it was before.
