I Need a Fuel Pressure Tester
Old Jul 2, 2009 | 12:07 PM
spdrmn282's Avatar
spdrmn282
Default I Need a Fuel Pressure Tester
There is not a garage around me that can check my fuel pressure for two more weeks.Where can I buy a tester for around $200.5.9L 24 Valve Cummins
Old Jul 2, 2009 | 02:13 PM
High_On_Diesel's Avatar
High_On_Diesel
Are you looking for a tester to check supply pressure, or injection pressure?
Old Jul 2, 2009 | 03:23 PM
spdrmn282's Avatar
spdrmn282
both but will I find one for that price that does both?doubt it
Old Jul 2, 2009 | 06:51 PM
High_On_Diesel
Maybe I can help. First off, what problems are you having bro?
Old Jul 2, 2009 | 10:46 PM
spdrmn282's Avatar
spdrmn282
I have a previous post titled power loss.I`m code 216 on my scanner which means fuel injector timing error.I`d explain everything again but my last post was long winded enough.Do me a favor and check it out.
Old Jul 2, 2009 | 10:48 PM
spdrmn282's Avatar
spdrmn282
The title is actually Extreme Power Loss.
Old Jul 3, 2009 | 01:22 AM
rabbler's Avatar
rabbler
What year is your truck?
If its 98.5-2001 with the vp44 injction pump, I'm sorry but you need a new injection pump and most likely a lift/transfer pump.
What is the actual P code? P0216?
Old Jul 3, 2009 | 01:29 PM
spdrmn282's Avatar
spdrmn282
It`s an `02 ,I think its the pump too but before I spend the money.I picked up an electronic high pressure meter.It must measure resistance and calculate it to PSI and Bars.Now I gotta figure out which wire sends the fuel pressure signal.Anybody got a wiring schematic of the plug that goes into the pump?Oh yeah I already replaced the low pressure pump.P0216 is the code.
Old Jun 4, 2012 | 11:41 AM
Charlie McCollum's Avatar
Charlie McCollum
I need part # 6923 for a tester. I have a 1997 Ram without a test port. My testor does not have the test adapte> Any ideas where to find one. One dealer referred me to snap on. Nothing in there catalog.
Old Jun 17, 2012 | 05:40 PM
Cartalk2's Avatar
Cartalk2
I would check with Geno's garage on tester. I bought a feed test pressure gage from them.
Good luck
