Changing/Checking injectors on '01 Cummins?
Old Aug 13, 2009 | 09:32 AM
hounds's Avatar
hounds
Default Changing/Checking injectors on '01 Cummins?
Is it difficult to change the injectors on an '01 Ram? Do they make a tool that screws over and they pull out? or does it need to be totally taken apart?
I have fuel leaking from where the injector lines are going into the block. They are tight but still fuel leaking out of 2 or 3 of them.
Truck starts fine and runs fine for about 30 minutes and after everything is all warmed up it spitters and spatters at idle and then is hard to start after sitting just even for 1 minute. Like the fuel is leaking back down the lines or whatever.
IS there O ring seals 'behind' the fuel line at/on the injectors that may need replacing? or possibly just loose injectors? What would cause fuel leakage here?
Thanks
Old Aug 21, 2009 | 01:31 AM
pizzo's Avatar
pizzo
Just buy new injector lines
Its hard for me to explain what the lines are like
And I don't think their is any orings
Give my your serial number I can look it up for you
