Time 4 a change ?
Old Dec 14, 2009 | 01:34 AM
Fedup6.0's Avatar
Fedup6.0
Default Time 4 a change ?
Hey guys ,first off I've got a 6.0 and I'm at the point of sh#t canning it! So , 5.9 or 6.7 ? I've read a fair amount of info and nothing major jumps out at me as bad ( see 6.0 ) I need a 4 door, 4x4,if it dont have it I"ll do the chip + exhaust thing, just the basics, stick or auto ? ofcourse I'll need a lift 4-6 will do.Can I use my 18 inch 2005 6.0 rims ? I thought i read somewhere they had the same bolt patern, I just dumped over 2k in tires + rims!I'll spend 23k-32K on a new rig 06-08 ? think that should get me in the game. I pull a 32 ft trailer 6-7 x a year, haul trees and rock and whatever else i can throw in the back, alot of freeway driving 80mph -90mph. Thanks in advance.
Old Dec 14, 2009 | 06:06 AM
Coal Train's Avatar
Coal Train
Fedup,
The engine choice depends on the year. The 07.5+ is where it went to the 6.7 and all the emissions stuff. 07 and earlier were 5.9.
There is nothing wrong with the 6.7, once you can the DPF and EGR. After that, it's an animal. Only problem is that there isn't nearly the amount of aftermarket stuff for it as the 5.9.
If you go with a 5.9, look at 04.5 - 07 common rails. Those were the higher HP trucks.
Your wheels won't fit. Ford uses that oddball 8 on 170mm bolt pattern and Dodge and Chevy use 8 on 6.5. They're close, but they don't fit.
If you need to know where to start on that Cummins, here ya go.....
Where To Start?
Old Dec 14, 2009 | 11:16 AM
Fedup6.0's Avatar
Fedup6.0
Thanks for the input Coal Train, I new 2 of the big 3 would fit ,course I have the funky one. Hell, can't let wheels stop me from moving forward. I belive I'll be looking into a Dodge this week,drive the 5.9 + 6.7's see what I like and go from there.Thanks again.
Old Dec 14, 2009 | 07:49 PM
OkState's Avatar
OkState
Don't know where you are but here in Oklahoma I just bought an 07 with the 6.7 with less than 12k miles for 28500. Most trucks were priced between 32-33 with the same miles.
Old Dec 15, 2009 | 03:53 PM
shakie's Avatar
shakie
I also dumped my 6.0 and that was the best thing I did I only have 12000 miles on my 2009 dodge so far so good.
Old Dec 18, 2009 | 03:17 PM
JoeV10's Avatar
JoeV10
Fedup- I'm not trying to hijack a thread here but I'm just curious what the problem with your 6.0 is? I imagine its a laundry list as often is with the motor. I do not personally own a Cummins, but have spent a ton of time around them. Everyone I have talked to that has a common rail loves them. I test drove an 06 and liked it,, but the truck was in pretty rough shape. Coaltrain is very right in regards to the 6.7. I love my Powestroke, but the Cummins is the better motor by a country mile. Best of luck on the new truck.
Old Dec 18, 2009 | 07:21 PM
NickBeek's Avatar
NickBeek
I came out of a 2004 6.0 too. You will love towing with a Cummins. If you are going to run 80 - 90 mph get the auto trans. I love my manual, but it is geared lower then the auto and it is turning more rpm's on the highway as a result. Now if you are towing that is great, but empty it gets annoying to me running 2400 rpm's at 75 mph. If you get a 6.7 built later in '09 you can't change the ecm with a programmer as Chrysler has put a booby trap in it.......
Old Dec 18, 2009 | 10:21 PM
Coal Train's Avatar
Coal Train
Actually Nick, most of them have worked around the Secure Boot Loader issue now.
Old Dec 19, 2009 | 04:27 PM
Fedup6.0's Avatar
Fedup6.0
Default Hey JoeV10
Yes the list is long!!! Head gaskets,turbo, injecters,EGR,and now low fuel pressure code. (in the shop now)I'm sure i missed a few little deals,but thoughs are the big ticket items.I've owned or should i say been owned by this truck about 20 months.Ford has coverd everything up to this point, thank the phuk for that.yes it is hoped up a bit ,but theres toomany stock 6.0s out there going too hell and back to blame it all on addon's.Whens this thing going to leave me high a dry miles from home? I wont wait to see.It's gone asap.
Old Dec 19, 2009 | 04:36 PM
Fedup6.0's Avatar
Fedup6.0
Nickbeek,thanks for the tranny info,never thought of that. course if put bigger meats on it w/a manual it might help out a little w/ the RPM's. I drive it more unloaded anyway+ with traffic a manual can be a PITA.Still need to think about it some more.
