Cummins lift pump?
I have a 05 dodge ram 3500, 4.10 gears, 5" exhaust & KN air cleaner. I want to replace my tank lift pump, but i see there are many diff. gph ratings what gph pump should i get for a basically stock cummins? leaning towards a airdog unit! Can i remove the existing fuel filter system? What about the electrical plug lines the are attached to the fuel filter unit?
Thanks
Thanks
For a basically stock truck, all you need is the AirDog 100. No need for anything bigger.
Yes, it will bypass the OEM filter housing.
The harness for the AirDog uses the OEM harness for power, it just bypasses the power to the stock lift pump.
The worst part about the install is dropping the tank......or removing the bed, whichever you prefer.
Let me know if you need a price on one.
