Difference behind 2000 47re and 2003 47re
Old Dec 16, 2009 | 05:43 AM
ice.v8's Avatar
ice.v8
Default Difference behind 2000 47re and 2003 47re
Hello, i have a 2003 3rd gen cummins with a 47re, i found a used 2000 47re with a lot of billet parts so i'm interested in the swap... what are the difference in the two tranny ?
i was told that the thread size of the hole that i circled in red in the pic is different, is this true ? any other problems ?
Old Dec 16, 2009 | 05:50 AM
Coal Train's Avatar
Coal Train
Yeah, actually that is a different size.
There are two different part numbers for the transmission coolant return lines.
One part number is for 98.5 - 02 and the other is for 03 - 07.
Old Dec 16, 2009 | 05:58 AM
ice.v8's Avatar
ice.v8
Oh thanks... do you know where i can find the 2003 thread size ? so i can rethread the hole on the 2000 47re before remove the tranny on my truck and have it ready to install...
Old Dec 16, 2009 | 06:51 AM
Coal Train's Avatar
Coal Train
Let me see if I have a tranny line laying around the shop and I'll check the thread size for ya.
No promises, but I'll take a peek. I think I have one.
Old Dec 16, 2009 | 07:35 AM
ice.v8's Avatar
ice.v8
wow great... if you can do this i will be very happy... here in italy i can't find info and so i have to ask in the states...
i thought that hole was for a sensor for the shift command... but you told it's for coolant return lines ?
any other issue for the swap ?
thanks again...
Old Dec 17, 2009 | 11:19 AM
Coal Train's Avatar
Coal Train
I thought I had at least one, but I don't.
I need to order a few lines to mod them for temp senders anyways.
Old Feb 5, 2010 | 11:03 AM
Chris Mallett's Avatar
Chris Mallett
thanks again...
You are correct. The 2000 model had a park/neutral safety switch there, the 03 has a range indicator in it. This is how your dash reads which gear it is in. And the thread is bigger on the 03 trans. More complex indicator, larger opening.
