Strange vibration in front right...
Old Dec 27, 2009 | 03:01 PM
joshkeely's Avatar
joshkeely
Default Strange vibration in front right...
Hey all! I just stumbled across this forum when searching for a solution to my problem...what a great place!!!
So here is my problem: I have recently noticed a vibration in my front right at practically all speeds. The vibration isnt too bad, but it is quite loud, as if I am driving over the rumble strips they put on the sides of the freeway. My initial thought was wheel bearing, so I jacked up the truck and tried to wiggle the tire up and down, but it is TIGHT....no slop at all. My tires were bald, so I decided this would be a good time to get a new set, thinking it was maybe a warped tire or out of balance...not the case. Even after new tires, and balance & front end alignment, it still is there......anyone have any idea what else it could be?
Thanks!!!
Josh
2003 Dodge RAM 3500 Diesel 2WD
Old Dec 27, 2009 | 03:06 PM
RHill's Avatar
RHill
Check your ball joints/ Shocks/ tierod ends. My guess is shocks or balljoints, these trucks are horrable on them. Mine only went 45k
Old Dec 27, 2009 | 06:09 PM
joshkeely's Avatar
joshkeely
Okay, so more data:
I noticed that, at ANY speed (5MPH or 55MPH), when I am going straight or left, it has this sound, however, when I turn just slightly to the right, and any place after this point, the sound goes away. Now I am thinking maybe power steering pump or something???
Thanks in advance for your help!!
Josh
Old Dec 28, 2009 | 09:09 PM
joshkeely's Avatar
joshkeely
Default Resolved!
Okay, so the Dodge dealer, a tire shop, and I all looked and ruled out a wheel bearing...apparently the old jack-it-up-and-wiggle-the-wheel method failed me! I couldn't see it being anything other than the wheel bearing, so I bit the bullet and bought a new hub and bearing set ($350!!!!!), and no more problems!!!
Thanks for your help!
Josh
Old Dec 28, 2009 | 11:25 PM
RHill's Avatar
RHill
I should have elaberated more.....
You have to do it on a tuesday with the wind @ 5mph from 52* northwest on a full moon to get a correct Knee to tire reading. Or have done it on all trucks and sizes for 20 years
Old Dec 29, 2009 | 12:18 AM
pizzo's Avatar
pizzo
Josh
Where did you get that wheel bearing at????
