2003 Dodge Ram 3500
Old Dec 28, 2009 | 05:39 PM
ernesto1950's Avatar
ernesto1950
Default 2003 Dodge Ram 3500
My 2003 ram would not accellerate after I tried to take off from a stop position. It stayed in idle. Now it only cranks but does not start. HELP
Old Jan 5, 2010 | 10:07 AM
Coal Train's Avatar
Coal Train
Is it throwing any codes.
A few things that will cause that condition.
1 - Bad APPS
2 - Bad FCA
3 - Fuel Rail Relief Valve
4 - Inoperative lift pump
Cycle the key from off to run 3 times within 5 seconds and leave it in the run position. This will display any codes on the odometer.
Old Jan 7, 2010 | 09:44 PM
ernesto1950
I'll be checking for codes following the procedure you recommended then I'll be back. Thanks.
