HELP!!! rear brakes!!
Old Mar 5, 2010 | 11:16 AM
yellowmopar3's Avatar
yellowmopar3
Default HELP!!! rear brakes!!
I am doing a complete brake job on a 2004 ram daully. How the hell do I get the rear rotors off. Just wondering if I have to take the hub nut off or just the 4 nuts on the back side. Any info is greatly appriciated! Thank you!!
Old Mar 5, 2010 | 05:30 PM
ecwrestoration@yahoo.com's Avatar
If you take the axle shaft out, i think you will find a large nut inside. If so, remove nut & bearing and it should come off.
Old Mar 5, 2010 | 08:15 PM
pizzo's Avatar
pizzo
I just did mine good luck its a PITA I thought... once you take the axle shaft out nut on the inside loosen that everything comes off
Old Mar 6, 2010 | 11:15 AM
yellowmopar3
Ok. So once I take that cover plate off and some fluid comes out, there is a nut in there that comes off and if I rememeber right it needs to be cranked down to some astronomical amount of foot pounds when putting back together.
Thanks for the info. It's greatly appriciated!!
Old Mar 6, 2010 | 08:04 PM
pizzo's Avatar
pizzo
The cover plate should be the hole axle shaft? hope we are talking about the same thing here .... When I took mine off the 6 bolts that are on the very end of the rotor take those out hit the face with a hammer so the seal will break loose then the Axle should be able to pull out.. Its too late now but Tomorrow I can take pictures and guide you through it???
Old Mar 7, 2010 | 01:17 PM
yellowmopar3
Default picture
That would be great. Thanks again!
Old Mar 7, 2010 | 03:20 PM
Coal Train's Avatar
Coal Train
Do yourself a favor and jack up the side you're working on and you won't get so much gear oil spillage.
