Problem
Old Mar 10, 2010 | 08:47 PM
2005RAM2500's Avatar
2005RAM2500
Default Problem
Just had my truck in getting an oil change/lube at Quicklanes. Later that evening took it out to the store, and no power steering when i pulled it over looked under the hood. Raidator was leaking and the belt was completly off?
What would cause this?
Bad water pump mabey? just my guess.
Old Mar 10, 2010 | 11:30 PM
pizzo's Avatar
pizzo
Where was the radiator leaking from?
When I bought my truck the Belt fell off I slipped the belt back on and never had a problem since.. I know that my Belt tensioner is bad.
Old Mar 11, 2010 | 06:34 AM
M.A.'s Avatar
M.A.
Radiator reservoir has a leak at the neck, I am planning on getting a new reservoir, What type of fluid do I need to use. I was told that the old type of green anti-freeze was not compatible with these motors, ram 1500 4.7? … Help
Old Mar 11, 2010 | 08:51 AM
steve05ram360's Avatar
steve05ram360
get Zerex G05 from Napa, about $11 bux a bottle.
Old Mar 11, 2010 | 11:52 AM
2005RAM2500
Turned out to be the bearing on the water pump, and broke the belt when it fell off.
