6 inch lift parts
Old Apr 6, 2010 | 09:06 PM
cbg32's Avatar
cbg32
Default 6 inch lift parts
Waz up,
I have 6 inch springs for my 1990 truck but am wondering what components I need with it. I looked online and different companies say different parts. here are some questionable parts from those companies: drop transfer case kit, 6% shims, drop pitman arm or steering arm, brake line relocation brackets, driveline spacer ect... any help would be appreciated.
Old Apr 9, 2010 | 02:13 AM
dodgetrucker75's Avatar
dodgetrucker75
i have 8" springs in my 75 which is bacically the same as your 90... you will need a drop pitman arm or steering arm, i run the drop pitman arm, a PITA to install but worth it in my mind, other than that all you really need is shocks, you can move the brake line mount at the frame to gain the nessasary clearence, and drive shaft lengths may need to be delt with, but dont use a spacer, if it needs to be longer, have a drive shaft shop extend it, DONT use the 6% axle shims!!! this will destroy your caster angle and make it impossible to drive in a straight line, and also dont use t-case drop brackets, hope this helps...
Old Apr 9, 2010 | 06:15 PM
cbg32's Avatar
cbg32
I custom made 6 inch springs, got a drop pitman arm, and some bilstein shocks. So how do you adress the front driveshaft angle problem correctly? Also, do I need to drop the sway bar? I can costom make that.
