PCV or somthing like it on a 12v?
Old Apr 18, 2010 | 10:36 PM
Mr. Byte's Avatar
Mr. Byte
Default PCV or somthing like it on a 12v?
On my '94, I'm blowing a LOT of oil out the road draft tube. I had assumed this was due to rings, and that I was doomed to using about a gallon of oil per tank, but someone else mentioned a blocked/clogged crankcase ventilation filter.
Does this exist on a '94 12 valve engine?
Can't seem to get the search function to run "CCV" or "PCV" for me, they're too short.
Thanks
Old Apr 19, 2010 | 10:54 AM
dodgetrucker75's Avatar
dodgetrucker75
there is no filter on the 12 valves, but one thing that can cause exsessive blow-by is a leaking vacume system, as the vac pump vents into the crankcase, other than that it would be your rings
Old Apr 20, 2010 | 07:19 AM
Mr. Byte's Avatar
Mr. Byte
That makes sense, as the cruise is weak above 65, like the vacuum is weak to it or something.
One more thing to look at. Thanks.
