2004.5 Truck with Error Code and other "issues"
Old Jun 8, 2010 | 03:27 PM
TJM's Avatar
TJM
Default 2004.5 Truck with Error Code and other "issues"
Just bought a 2004.5 yesterday. The error code P0483 (cooling fan speed) comes up when I check for codes. The check engine light hasn't come on for me- I just decided to check for codes to make sure everything was running well.
Also- my cruise control doesn't work. Any idea on how to fix that.
Lastly- the outside air temperature is way off. It's 60 out and it will tell me it's 93 or higher. Any insigt on that?
Thanks!
Old Jun 8, 2010 | 10:25 PM
pizzo's Avatar
pizzo
the fan clutch maybe going bad but have to check the wires first.. and the Cruise control the vac pump is located on the passenger inner fender you will need to see if that is working... it maybe burnt up but you also may have a leak somewhere.. Take hoses off and test with gauge...
