Dodge Tech Please
Old Jun 9, 2010 | 11:01 AM
buckskin's Avatar
buckskin
Default Dodge Tech Please
Hi I know this is hte wrong forum but this is the one I frequent the most. I have a 1990 Chrysler New Yorker 3.3 v6. The car has 34k miles on it never had a problem. Yesterday the car was running fine, parked came out car starts then immediatley dies. It will do this over and over. Bad fuel pump? sensor of some kind? Thanks in advance for any info.
Old Jun 13, 2010 | 01:52 PM
Spc_Sapper's Avatar
Spc_Sapper
sounds like a fuel pump. or map sensor
Old Jun 13, 2010 | 10:06 PM
YAMAHARIDER5's Avatar
YAMAHARIDER5
Fuel pump is probly bad, or theirs a cracked vacuum line somewhere, Or possibly bad cam or crank sensor
Old Jun 14, 2010 | 08:50 AM
ET RAM's Avatar
ET RAM
Some of the older Chrysler vehicle have a ballast resistor installed. When this resistor fails, you get the symptoms posted: engine starts but turns off when you let the key go to on.
The only one I remember was on the firewall behind the engine and looked like .5x3" electrical connector. As best I can remember. You can wire it to bypass the resistor and the engine will stay running until you replace it.
Old Jun 14, 2010 | 11:00 AM
buckskin's Avatar
buckskin
Thanks for the info. I have read there were issues with the anti theft systems on these cars?
