318 to 24 valve 5.9 swap
Hey guys. I have already had some great experience with this forum and now have another question for you guys! I want to swap the 318 in my 1998 regular cab shortbox for a 24v 5.9 cummins. Where I am its roughly 18000 dollar average for a 2000 - 2002 ram 2500 so I figured an engine swap would be a little cheaper than 18 grand.
So I have googled it and some say its a direct drop in but I'm not to sure. I know I will be purchasing an engine, tranny and all the little things in between. Will I be needing heavier suspension? I did read that if you do the swap using 2500 or 3500 front springs is the way to go. Another thing is would it matter what year the 5.9 was? I mean the engine will be getting a nice working over and some nice power-adders.
Do you reccomend this or should I just muster up the 18000 and get a 2500?
It can and has been done. I have a read a few posts about it and there seems to be a million little details that can eat you up. Do your research before you begin, and have your ducks in a row. Also you would make things much easier on yourself if you used a 12v engine. Keep us posted on your progress.
i recomend a 12 valve also. i will put it out there that i have no experience in this, but from what ive read thats more of a way to go. as you said its all mechanical construction. you will probably have to have a custom made driveshaft as they didnt put cummins in regular cab, short beds. the best thing to do is get a donor truck. because your gonna need a new front suspention, motor mounts, battery tray. little tid bits as mentioned above. best thing to do, find a donor truck and go from there
