loose throttle linkage 98 ram
Old Jul 16, 2010 | 09:02 AM
venusnhosr's Avatar
venusnhosr
Default loose throttle linkage 98 ram
where my throttle cable attaches and pivot on the injection pump has alot of play in the area...truck has 225xxx miles and has manual trans...how do you correct this problem...dies when coming to an idle at stop sign some times...any help would be great
thanks scott
Old Jul 16, 2010 | 10:56 AM
dodgetrucker75's Avatar
dodgetrucker75
that wont cause the stalling issue, you just need to turn the idle up a little, i'm assuming its a 12 valve engine, correct? the idle should be 800-850 rpm with the a/c on
Old Jul 17, 2010 | 05:33 PM
venusnhosr's Avatar
venusnhosr
is your diagram the injector pump...
Old Jul 17, 2010 | 05:42 PM
dodgetrucker75
sorry, yes it is the rear of the injection pump looking from the driver side, the low idle screw is what you want to adjust
