Prospective Ram owner
Old Jul 21, 2010 | 12:55 AM
jc8825's Avatar
jc8825
Default Prospective Ram owner
I am looking into possibly buying a 1998 Ram 2500 Extended Cab, LB, 4x4 automatic with the 5.9 Cummins. What I would like to know is if there are any problems associated with this generation of trucks. I realize the engine depends on the service records, and I will check that out. Really, though, what about 4wd components? Do they wear out? Ball joints? Frames breaking (Ford SD owners claim that that happens a lot.) My wife's parents have had bad luck with 2 different Caravans and burnt up transmissions. I have a mechanic friend that claims that Dodges without a tranny cooler will have failed transmissions. Does the 98 have a tranny cooler? I have been a Ford guy, so I need more info on diesel Dodges. Thanks.
Old Jul 21, 2010 | 01:04 AM
TruckinDodge's Avatar
TruckinDodge
You might have better luck with the diesel section of the forum. I haven't heard anything about a frame problem but you could always box it, if your worried about it.
Old Jul 21, 2010 | 01:15 AM
dodgetrucker75's Avatar
dodgetrucker75
no problems with the frames, ball joints do wear out as they do on all vehicals, mine made it 200k before i replaced them, with 6in lift and 35's, the trans all depends on how well it was taken care of (maintence) and how it has been treated, and it does have a stock cooler, is it a 12v or 24v?
Old Jul 21, 2010 | 01:48 AM
jc8825's Avatar
jc8825
12v I think. It is an early 1998 model (11/97).
Old Jul 21, 2010 | 02:07 AM
jasonw's Avatar
jasonw
Site Moderator
Let me move this to the diesel section for you, more answers there I think, since you are looking at a Cummins.
