fuel pressure
Old Aug 4, 2010 | 06:41 PM
dbarto's Avatar
dbarto
Default fuel pressure
I have a 2000 dodge ram 3500 diesel,i have a fuel guage on .
when i start truck it has 10-12 psi at idle
when driving with a load on ,have 3000 lb camper on back
it drops between 4 and 7 psi , when get up to 55 mph to 65 mph will go up to between 6 to 8 psi, is this pressure ok , or do i need to look at replacing lift pump
Old Aug 5, 2010 | 02:26 AM
dodgetrucker75's Avatar
dodgetrucker75
you are ok, if you start dropping below about 5psi, something needs to be changed, but you have normal pressure... for now, keep a good eye on it
Old Aug 17, 2010 | 06:00 PM
dbarto's Avatar
dbarto
i replaced lift pump with airtek pump(couldnt get a fass in time for trip)
now at idle, it runs at 18 to 21psi and 15 to 16 psi when pushing down throttle, is this pressure to high or is this ok, drove it on trip 650 miles
Old Aug 17, 2010 | 06:16 PM
horatio102's Avatar
horatio102
No it's fine, the extra fuel just cools your lift pump and gets sent back into the tank.
Old Aug 18, 2010 | 09:25 AM
Coal Train's Avatar
Coal Train
For both the CP3 and VP44, you want the pressure between 10 and 20 psi.
Ideally between 13 - 17 psi.
17 psi at idle and no lower than 13 psi at WOT will keep your injection pump happy.
Pressure below 7 psi on the VP44 is not what you want to see. The VP44, unlike the CP3, cannot draw it's own fuel and NEEDS good pressure. The fuel is it's cooling and lubrication.
The CP3 has it's own internal lift pump and is capable of drawing it's own fuel, but initially needs the pressure for starting, otherwise hard starts can occur. The CP3 needs volume more than it needs pressure.
Old Aug 19, 2010 | 11:00 AM
2005RAM2500's Avatar
2005RAM2500
I have a 2005 2500 and running 8 psi at idle, and drops bellow 5 PSI under acceleration, do I need a lift pump? measured from the bottom of the Fuel filter. Thought it was ok, until I saw your post. Thanks
Old Aug 22, 2010 | 02:41 PM
Coal Train's Avatar
Coal Train
As long as the CP3 has any pressure at all, it's okay.
The CP3 has it's own internal lift pump that pulls it's own fuel, so the pressure isn't as critical.
It's not ideal, nor will it make full power with upgrades, but you're not going to damage it.
The VP44 in the 24V trucks needs the pressure. When the VP's pressure gets down into that 5-7 psi range, that's when you want to upgrade the pump.
You're fine though......although 13 - 17 psi is where you ideally want the pressure to be.
