02 2500 4x4 Brake Issues
Old Aug 31, 2010 | 05:59 PM
big 29's Avatar
big 29
Question 02 2500 4x4 Brake Issues
I recently replaced my front pads on my '02 2500 4x4. I found, after a seemingly easy installation, that my abs light and brake light were on and my power assist on brakes didn't work. I have test drove it and have brakes but they are at the floor. I have bleed them several times and have reset the computer but to no avail. Anyone ran across this problem before or have any insight?
Old Sep 1, 2010 | 12:56 AM
tski's Avatar
tski
i have about the same problem. only mine pulls hard to the right when you first step on the whoa pedal then it pulls back to the left and after that they work fine.... abs pump have air in it?
Old Sep 1, 2010 | 01:34 PM
horatio102's Avatar
horatio102
Are you leaking brake fluid? Reservoir full? Sounds like air in the lines, not to be an *** but are you bleeding them properly?
Old Sep 7, 2010 | 02:44 AM
big 29's Avatar
big 29
So i found my problem. I re-bleed all 4 brakes with my buddy's gravity feed machine. My best guess was air was trapped up by the master cylinder or the ABS unit.
Old Sep 8, 2010 | 11:58 AM
horatio102's Avatar
horatio102
Glad it's fixed!
