vp44 fuel additives?
Old Sep 4, 2010 | 07:49 PM
bigdip's Avatar
bigdip
Default vp44 fuel additives?
I just got an '01 cummins last week with 330k miles, the injector pump, lines, and injectors have been replaced by one of the previous owners.
I was wondering if its a good idea to put any additives in the fuel, to help with lubrication, since thats why most vp44s fail right? And what would be a good additive to use? thanks
Old Sep 4, 2010 | 08:24 PM
bigdip's Avatar
bigdip
and does anyone know if a 2006 turbo will fit ? i found one cheap and mine is leaking oil.
Old Sep 5, 2010 | 12:59 PM
dodgetrucker75's Avatar
dodgetrucker75
you should really install a fuel pressure gauge to moniter, low pressure what kills the VP most of the time, but a lot of guys use 2-cycle mix for extra lubrication, the 06 turbo will work but will require some additional work as the exhaust is a little different and the outlet to the intercooler is pointed at a different angle
Old Sep 5, 2010 | 11:15 PM
bigdip's Avatar
bigdip
I've done some research and I'm going to order a triple gauge pillar. I'll put egt, trans, and fuel pressure.
how much 2 cycle mix per full tank?
Old Sep 7, 2010 | 03:12 PM
dodgetrucker75
some run just a few ounces and some run a quart per tank, just personal prefrence, the gauges are a great piece of mind...
