06 Common Rail Mods
Old Sep 15, 2010 | 08:23 AM
Oklahomacummins's Avatar
Oklahomacummins
Post 06 Common Rail Mods
I am wanting to advance my injection pump in my 06 2500 common rail. I am fairly new to the cummins world and I am unsure if I am picturing it right in my head. I have removed the silencer ring from my turbo as well as all the bs baffling from my intake tube. Just wanting to do small mods right now but plan on running dual cp3's, aftermarket lift pump, stacks and programmer but wanting to stay moderate for now. Any info from anyone would be awesome also pics if you have any.
Old Sep 15, 2010 | 02:49 PM
dodgetrucker75's Avatar
dodgetrucker75
there is no timing adjustments on your pump, only programmers can change timing, and before you do any of thoes things you mentioned, you should have a set of gauges installed first, and if auto tranny, a minimum of a performance valve body and torque converter should be installed
Old Jan 25, 2011 | 03:59 PM
kainedogg's Avatar
kainedogg
I know this thread is old but I needed to revive it. What valve body and torque converter is recommended for the third gen 48's
Old Jan 25, 2011 | 06:03 PM
dodgetrucker75
look into gorend or suncoast
Old Jan 26, 2011 | 09:06 AM
kainedogg's Avatar
kainedogg
I will do that. Very slick bumper by the way.
Old Feb 11, 2011 | 12:45 AM
05 RAM 2500's Avatar
05 RAM 2500
i have a smarty jr on my 05 cummins and i have read and been told by mechanics that the gauges are needed but they said unless your racing alot the trans they have in theses trucks should hold up but if you add a chip on top of it then you need to build it up they are good for over a 100 horse pass stock i have read
