Help with 5 speed issue for a 99 cummins?
Old Oct 10, 2010 | 09:32 PM
99withflat's Avatar
99withflat
Default Help with 5 speed issue for a 99 cummins?
Im ok with the simple stuff on trucks but i need help on this. Fifth gear has went out on my 1999 dodge with the 5.9 cummins and a five speed transmission. I have heard this is a common issue, a nut backing off of a pin making the gear unusable. most people say they have had mechanics say they drill through the pin and put another pin in to keep the nut from backing off. how should i fix this?
Old Nov 14, 2010 | 11:48 AM
99WORKTRUCK's Avatar
99WORKTRUCK
I cleaned the nut and the threads on the shaft with brake clean, then used lock tight to secure the nut.
Old Nov 16, 2010 | 03:46 PM
dodgetrucker75's Avatar
dodgetrucker75
that should work fine, some buy a second nut and double nut with locktight
Old Nov 16, 2010 | 04:38 PM
12valveman's Avatar
12valveman
the revised nut from dodge uses locktite and when torqued you tighten a screw in the nut to tighten it tighter to the shaft that is a fix have used on customer trucks and have never seen one back again
