snap krackle POP...steering....
Old Nov 14, 2010 | 09:17 PM
ifUcantdodgem-ram'em's Avatar
Angry snap krackle POP...steering....
HELP>>>> my 07 ram 3500 drw steering wheel (??) snaps, krackles and pops. Ive replaced the clock spring and multifunction switch and still the Snap,krackle and POPs... any one else have this issue or have heard of this problem? thanx for the help.....
Old Nov 15, 2010 | 01:57 AM
bigdaddyII's Avatar
bigdaddyII
May be a far stretch from your issue, but my 02 1500 did the same thing when I bought it last year. I knew it had a bad front suspension when I bought it, and all the noises and "feel" went away after I changed the ball joints. Is your truck 4 or 2 wheel drive?
Old Nov 15, 2010 | 12:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why not take the steering column apart and lift the front end off the ground and turn the wheel back and forth and listen/see where it is coming from?
Also, moved to the CTD section for more help
Old Nov 30, 2010 | 09:34 AM
carisu's Avatar
carisu
sounds like ball joints. have someone look at the steering components under your truck while you turn the wheel back and forth. you can usually see the problem area that way.
