Stuck in 4h
Old Dec 24, 2010 | 06:42 PM
kahlmant's Avatar
kahlmant
Default Stuck in 4h
Today I was given a truck for $1. It is a 94 12 valve. Needs some work as you can imagine, but all and all in great shape mechanically. The only problem is that it is stuck in 4h and I can't shift it into 4L, Neutral, or 2wd. Any ideas what good be the problem and how to fix it. Thanks guys.
Old Dec 25, 2010 | 08:46 AM
98Dakota's Avatar
98Dakota
about once a year i end up tighting up the bolt that holds the shifting linkage to the transfer case maybe yours is backing off as well ??
Old Dec 25, 2010 | 10:32 PM
Scott91370's Avatar
Scott91370
I had an issue similar to this and on mine one of the large C clips inside the t-case had fallen off not letting the sifter move. I bougth the new clip, range fork, seals and fluid. Total cost to pull it apart (myself) and fix it was under $100. I used the FSM and it was perfect for this job.
Only way to tell if this is it is to open her up.
