Noob question
Old Feb 6, 2011 | 12:48 PM
M.Wise's Avatar
M.Wise
Default Noob question
I have a 05 2500 4x4 with the cummins Diesel with 98K miles on it....The question is I have done nothing but oil changes on it. And air filters.....Is there anything else I need to do....Run the top rack or anything like that??????
Thanks
Old Feb 7, 2011 | 12:21 AM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Fuel filter changes.
Transmission fluid/filter changes.
Band adjustment
Differential oil changes.
Ball joints
U-joints
Track bar bushings
Brakes
Tires
Wiper Blades
Washer fluid
Cabin air filter
Power steering fluid
Anti-Freeze flush/refill
Wheel bearings
Air pressure in the tires
Drain the water in the fuel
Steering rack
Lights
Ummm.....That looks like a good start for a list of things to do/check/replace
Old Feb 7, 2011 | 06:41 PM
horatio102's Avatar
horatio102
That should about cover it.
Number one is to do your fuel filter right away. Number two would be fluid drain and fills.
Old Feb 7, 2011 | 09:18 PM
M.Wise's Avatar
M.Wise
Thanks...Going to do the fuel filter this weekend....Now for the front and rear differential's...What lube should I use???? And can I use the same in transfer case too???
Next I will be doing the trans...
Thanks
Old Feb 8, 2011 | 09:28 PM
horatio102's Avatar
horatio102
For my '08, differentials are full synthetic 75w-90 gear lube. Trans (68rfe) and transfer case (np273) are both ATF +4, as is power steering.
