OBDII Link Error & Check Engine Light
Vehicle - 98-1/2 Dodge 2500 Ram, 24-valve diesel engine
Problem - ck engine light is on...get link error on OBDII diagnostic code reader
Symptoms - some fluctuation in idle speed....but steady now
I tried the key trick 3 times on & off (from off to ON to off to ON to off to ON) but don't get any codes on odometer....just mileage & no blinking of check engine light.
I do have a fuel pressure gauge installed that I purchased from Geno's & it shows pressure 12+ lbs.
Only recent work I did was to remove one of the intake hoses (between turbo & intercooler) that was leaking & left system overnight (did a mouse crawl in?) & then reinstalled the intake hose the next day. Hose was not bad....clamp had slipped off side of hose...so just reinstalled.
Suggestions???
Suggestions???
