long hot crank
just replaced my vp 44 on my 99 because i thought that was it and it was under warranty. i do not seam to have any fuel leeks and the truck starts instantly cold or an over night cold soak. im a diesel tech and im stumped i mostly work on international and cats because the big truck cummins never brake down
please i need some info or help because i look stupid cranking my truck for 20 seconds or more
You say you replaced the VP44 however did you infact change the lift pump as well?
You may have already dammaged your new injector pump because it is being starved by the lift pump. The OEM lift pump produced by Cummins in the 24 valve units sucked big time.
Corrections have been made by Bosch to produce a good replacement.
Good luck!
Good luck!
Thanks crazzydan. How did you find that out?
