Tranny Problem/ Tranny Grounds
So i have been having tranny problems for the past couple days now. Ill be driving around and around 70mph and the tranny will down shift or up shift. Today **hit hit the fan almost got stranded 45 minutes from home. So this is the problem these are what I've heard. One adjustment of bands. Two band battery grounds. And last but not least a bad tranny ground. Now i don't know what or where the ground is but i think i found it just need some A Team help on making sure i'm right. Below is three pics of what looks like a ground ribbon that's hanging on by a thread. It looks like it go's up into the top part of the tranny. Can anybody identify this problem and PLEASE help me out here. Also anything else that might be the problem. Things i have already tried to fix. One flushed tranny Two cleaned battery terminals very well and three? well i guess its just two. Please help there will be a bottle of Jack Daniels Fedex to whoever helps with this problem and its the solution
Hi all. If it helps, mine had the same symptoms. What I could observe is that anything electronic such as locking or downshifting to 1st or O/D button works, neither A/C or the RPM and speed gauges in the instrument cluster. All at the same time. It'd easy for me to surmise that it's a faulty ground. Checking tomorrow.
