Bullydog 40420 VS Edge EZ module
Old Jun 1, 2011 | 12:47 AM
Bayboss's Avatar
Bayboss
Default Bullydog 40420 VS Edge EZ module
I am looking at these to tuners. What are there pro and cons from people that use them now?
Should I consider any other tuner?
I have a 2006 2500 diesel and do some towing. I am looking for performance gains and better gas mileage when I want it.
Thanks
Old Jun 9, 2011 | 03:48 PM
(texas-ram)325HP's Avatar
(texas-ram)325HP
Look into a Hypertech Maxenergy ECON if your going for MPG and a little more power for towing
Old Jun 11, 2011 | 07:14 PM
horatio102's Avatar
horatio102
Everyone I've spoken with doesn't have good things to say about Bullydog - makes the most power they say, but destroys transmissions in doing so.
Old Jun 12, 2011 | 02:19 PM
(texas-ram)325HP
a bully dog doesnt make the most power and a smarty will demolish a tranny too so will a edge juice predator... but for what he wants id get the Hypertech Maxenergy ECON or a Edge Jucie or smarty Jr
Old Jun 13, 2011 | 03:08 PM
Pull Ya's Avatar
Pull Ya
The Edge EZ has the ability to shift on the fly. It has 3 setttings that you can use. I think the "top" setting was like +60hp or so. Your transmission and turbo will be OK as long as your hp increase is under about 90hp(this is a practical rule of thumb). Smarty Jr. is also a good choice. If you have trans problems you should look into Goerend Trans. They are bulletproof--although they aren't very cheap. The first thing you should invest in is a good set of gauges so you can tell what's happening--EGT, Boost, trans temp and fuel pressure at the least.
Jay
Old Jun 13, 2011 | 09:30 PM
(texas-ram)325HP
A shift kit might be good if your not looking for tons of poor
