Making Oil?
Old Jun 15, 2011 | 07:21 PM
jon3030's Avatar
jon3030
Default Making Oil?
Had my first oil change (Amsoil) about 700 miles ago. Just pulled the stick and my oil level is about 1/2" into the metal of the dipstick....surely it was not overfilled, could the emissions junk be causing it to "make oil". Is this level high enough to cause engine damage?
Old Jun 15, 2011 | 07:22 PM
jon3030's Avatar
jon3030
Forgot to add that it is a 2011 6.7 motor
Old Jun 16, 2011 | 10:41 AM
98Dakota's Avatar
98Dakota
i hope you are not getting fuel into your oil causing the rise??that would not be a good thing at all ..
Old Jun 16, 2011 | 03:51 PM
dodgetrucker75's Avatar
dodgetrucker75
it was either over filled, or you have an injector or injector tube leakin fuel into the crankcase, also checking a hot engine can also give the appearence of being a bit over full
Old Jun 16, 2011 | 06:10 PM
Tazman40's Avatar
Tazman40
make sure its dead level when checking.If my 5.9 is pointed the slightest little bit up hill it will be over full by a quarter inch or so.Theres alot of oil in there so if its unlevel either way it will make a difference.
Old Jun 16, 2011 | 11:35 PM
horatio102's Avatar
horatio102
I'm pretty sure there was a bulletin on this.
Anyway, unless I was smoking too much crack the day I read that bulletin, the 6.7 tends to retain a bunch of oil in the CCV filter and it requires a mildly extended oil drain interval.
Or just change the oil after the truck has been sitting for a while.
BUT, if you've let the oil drain for long enough, and it still seems to be gaining oil, then I'd suspect a fuel injector.
Old Jun 19, 2011 | 07:14 AM
redtruck2500's Avatar
redtruck2500
Oil analysis ?
