Rear window don't work
Old Jul 6, 2011 | 10:58 PM
cchavez06's Avatar
cchavez06
Default Rear window don't work
I need some help fellas. My driver side rear window rolled down the other day and decided it did not want to go back up. It wouldn't go up using the master switch on the drivers door or on the rear drivers switch either. I can hear the motor engaging trying to go down off of the rear switch but nothing engages when trying to roll it up. There is power to the brushes when the window switch is engaged in the up position but nothing engages. That's as far as I know to take it. What possibly else could be causing the issue? Any help is appreciated.
Old Jul 16, 2011 | 09:13 PM
ramcrazy2011's Avatar
ramcrazy2011
window motor or actuator or the tracks could be in a bind and need tobe freed up take the door panel off and cheak it out
Old Jul 17, 2011 | 12:44 AM
1Normy's Avatar
1Normy
cchavez06 You might check your wiring harness that goes between the door and the body. I had problems on my truck with the left rear door not locking and eventually the left rear speaker quit as well. I chased it down to broken wires in the flexible boot that goes between the door and the body. Ended up repairing them and all works fine now. I may even have some pictures. If I can find them I will post them later.
