Help help help
Old Oct 19, 2011 | 09:01 PM
idaho2500's Avatar
idaho2500
Default Help help help
I just installed the FASS DDRP 02 replace ment pump and on step 4 it says to unplug the wire harness from the pump after you remove it and I HAVE NO PUMP?? just a block of alum and no wire harness it looks to me the pump is in the tank???? is there a pluge for it up front?? /anyone els have this problem??
Old Oct 20, 2011 | 10:33 PM
idaho2500's Avatar
idaho2500
Well thanks for all the info I guess I am the only one to ever find this out the hard way! Stuped web site I picked this up at says ".5 install time direct fit real easy save youe IP pump more power! NOTHING about you could have the pump in the tank! YAA I should have looked but dang!
My FASS DDRP 02 is a fuel pump replacment thats if your pump is next to your IP pump BUT mine is in the tank, so I am thinking of cutting the fuel line next to the tank and splicing into the 12v ckt for the tank pump what do you guys think about that?
GOOD OR BAD?
