Cummins R.P.M. bouncing while in overdrive
Old Nov 28, 2011 | 09:52 PM
ixijimixi's Avatar
ixijimixi
Default Cummins R.P.M. bouncing while in overdrive
When i get over 50 mph it bounces between 1400 rpm and 1800 rpm. At first i thought it was not catching overdrive the right way. BUT i pressed off the overdrive button on the shifter and the rpms jumped to 2200 as if it was actually in overdrive. It has a switch that when i turn it on it holds it at 1800 rpm's what causes this
Old Nov 28, 2011 | 11:28 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
What year? What engine? What trans?
Old Nov 29, 2011 | 06:34 PM
ixijimixi's Avatar
ixijimixi
1998 24 valve idk about the tranny whatever is stock auto with overdrive for the 98 24 valve
Old Dec 3, 2011 | 05:07 PM
xtech's Avatar
xtech
When I worked at Dodge I had one doing that and it ended up being the electric fuel pump (supply pump for the injection pump). RF interfence to the tps signal in the jtec controller.
