2010 6.7L cummins drive line noise
Old Dec 4, 2011 | 09:36 PM
diesel 2010's Avatar
diesel 2010
Default 2010 6.7L cummins drive line noise
i have a wierd niose comming from either the tran or rear end when i'm pulling a heavy load it almost sounds like the gears in the rear end are skipping and i get alot of vibration in the truck. i also get alot of that vibration in the truck when i'm not pulling but it doesnt happen as much.
i'm a first time diesel owner so havent had any expierence with these trucks till now. has anyone had this issue or know what might be happening so i know what to have a look at.
thw truck is a 2010 dodge mega cab 3500 srw, 35" tire and a H&S programmer.
thanks
Old Dec 5, 2011 | 06:13 PM
jeff-ab9uw's Avatar
jeff-ab9uw
Is this an auto or manual? How high are you running the H&S? How heavy are you towing?
Jeff.
Old Dec 6, 2011 | 08:55 AM
diesel 2010
Jeff.
It is auto, I run my H&S on wild setting, and my load was 12000lbs.
Old Dec 7, 2011 | 12:36 AM
Nokturnalhtx's Avatar
Nokturnalhtx
I have a 2008 6.7 and I'm getting mouselike sworn belt coming out of my turbo any suggestions? Thanks...
Old Dec 7, 2011 | 12:37 AM
Nokturnalhtx
Noise like warn not mouselike sworn lol sorry
Old Dec 8, 2011 | 06:35 PM
jeff-ab9uw's Avatar
jeff-ab9uw
diesel 2010; I really have no idea what the "skipping" might be. I'm suspecting the vibration and possibly the skipping is in the trans. Very possibly the overdrives in the trans. This is going by the experiences of others on various cummins forums. The 68rfe trans doesn't like a lot of power going through the overdrives, especially when towing.
Theres a guy over on www.cumminsforum.com, trans engineer. He's a dodge engineer for this trans. I'll bet he can point you in the right direction, if it is a trans issue.
Jeff.
Old Dec 9, 2011 | 08:51 AM
Nokturnalhtx
Well I feel so dumb turns out one of my exhaust manifolds was a little loose and the noise was the gasket wistleing I tightened it up and truck runs perfect... Feeewwwww got a little worried there...
