dead key?
Old Dec 14, 2011 | 06:43 PM
tredgti318's Avatar
tredgti318
Default dead key?
hi i have a 95 cummins 3500. recently replaced the transmission lines and i went to start it today and it had a dead key. i figured it was the battery so i threw a charger on it. turned the key and nothing. the radio and lights all work, and it says its getting 14 volts sometimes it jumps up to around 18 volts. when i turn the key the lights dim and the radio goes dead. is there some kind of fuseable link to the starter? the starter is only a few months old. i checked the fuses in the fusebox in the engine compartment and they look okay. i swapped around relays and it didnt help. i checked the "engine" fuse in the fusebox by the drivers door compartment and it was good. anything im missing? i let the batterys charge and no change. could it be an overcharged battery that popped the fuse? any help would be appreciated. thanks, Nick
Old Dec 15, 2011 | 09:17 AM
verdesardog's Avatar
verdesardog
The batteries read good voltage with no load but the voltage drops when a load is put on them. Sounds like bad batteries to me or a loose connection somewhere.
