throwing a timing ctrl circ error code after installing superchip flashpaq 3805
Old Dec 14, 2011 | 11:33 PM
zach_b's Avatar
zach_b
Default throwing a timing ctrl circ error code after installing superchip flashpaq 3805
so i put a superchip 3805 on my 02 runs good but when i run a diagnostic test on it its coming up as a timing ctrl circ error code #po216 so i took it back to stock tune the code was not there any more,i put the tune back on to the truck and it still did not come back up when i read the diagnostic test. could this be because the injection pump needs to be adjustet? if so how do you adjust it and how do you know how much adjust it. PLEASE HELP!!!
Old Dec 15, 2011 | 10:25 PM
jeff-ab9uw's Avatar
jeff-ab9uw
Been a while since I had my '00 or '01 trucks but from what i remember there is no adjustment you can do on them. Aside from physically pulling the pump out and re-installing it out of time. All the timing is done with the electronics and is internal. Further, timing codes with the vp-44 was an indication of a failing pump.
Jeff.
Old Dec 15, 2011 | 10:39 PM
zach_b's Avatar
zach_b
it did not start doing this till i put the tuner on the truck could the extra amount of fuel being pushed cause this code to be thrown?
Old Dec 15, 2011 | 11:38 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
That's a death code for the VP-44. You probably have a dead lift pump as well. Get a fuel pressure gauge on the low pressure side. You should have 10-15 psi.
Old Dec 16, 2011 | 10:42 PM
jeff-ab9uw's Avatar
jeff-ab9uw
Could be the pump was on the edge. Adding the tuner pushed the timing (or some other parameter) out of tolerance.
jeff
Old Dec 23, 2011 | 10:23 PM
zach_b's Avatar
zach_b
prolly so cuz the truck runs fine still runnin like a champ just is throwing the code ever so often
