6.7 problems! Please help!
I've had a trouble code cup upp that says I have lost communication with my TCM. Need help as to what I need to do to fix it!! What could I have done wrong?
If it is still intact what else could be the problem? The CEL comes on along with the Trans temp light but my temp is normal. Could a bad alternator be messing with the computer on the truck making it throw codes that arent even a problem? Or could a bad battery be giving it trouble as well?
The batteries are known to cause weird problems when they start going bad, so a bad or weak battery is certainly a possibility. I don't know when they made the change but the newer trucks (maybe '10+?)are supposed to have upgraded batteries (similar to the odyssey agm), so maybe they won't be quite as problematic.
Also, I believe there was a problem with wire chaffing on some of the pre-2010 trucks. It didn't fall into the model year of truck I had so, I didn't read up on it much.
You can check on www.cumminsforum.com . That's where I saw someone talking about the wire chaffing issue.
Jeff.
Jeff.
