2011 2500 idling with door lock control?
Old Jan 24, 2012 | 01:29 PM
thirtydaZe's Avatar
thirtydaZe
Default 2011 2500 idling with door lock control?
i'd like to know if it's possible to idle the truck and have control of locking/unlocking the doors.
for instance i want to run into the convenience store, leave my truck running, but lock the doors, is it possible?
can you leave the fob in the ignition, remove the key portion, and lock and unlock the truck at will with the engine running?
Old Jan 24, 2012 | 03:03 PM
DodgeCares's Avatar
DodgeCares
Thirty,
You would need to remove the emergency key from the FOB and manually lock and unlock your vehicle. There is no way I am aware of to lock the vehicle with the FOB in the ignition, either running or not, besides manually pushing the button down to lock and using the emergency key to unlock. If you had the other FOB the unlock feature would work on it but I assume you are asking about only using one.
Old Jan 24, 2012 | 04:21 PM
thirtydaZe's Avatar
thirtydaZe
Originally Posted by DodgeCares
Thirty,
Yeah that was my question, if i could still get in and out with the emergency key.
Is leaving it idle not common practice in thecold for quick trips into the store?
Old Jan 25, 2012 | 09:40 AM
DodgeCares's Avatar
DodgeCares
Thirty,
Not that it is not common, but the system is designed to try and prevent people from locking their keys (Fobs) in the car. I had the same problem as I often left my truck running with the air on when I take my dogs with me in the summer. Once I got my remote start it solved this problem as I would lock everything up and hit my remote start upon leaving. This would give me 15-20 minutes without having to worry.
Old Jan 25, 2012 | 10:28 AM
thirtydaZe's Avatar
thirtydaZe
Thirty,
well definitely looks like after market is the only option. i experimented last night with the emergency key. all it would lock/unlock was the drivers door.
tried to manually lock the other doors with the power lock button, but they would not work.
thanks for all your input.
