Cummins Noise Issue- with video
Old Jan 27, 2012 | 07:31 PM
dieseldaves's Avatar
dieseldaves
Default Cummins Noise Issue- with video
This noise just started happening on hard accelerations and decent highway grade climbs.
Truck is bone stock.
Thanks for your help folks.
my YouTube video of the problem noise
Old Jan 28, 2012 | 07:08 PM
hillbilli's Avatar
hillbilli
Have you checked your u-joints?
Old Jan 28, 2012 | 09:42 PM
rickf1985's Avatar
rickf1985
Mine was doing the same thing and I eventually found a loose boot clamp. If you have had them off and on then that should not be it but mine sounded exactly like that. High pitched scream like a turbo but does not vary like a turbo. Could be a minute tear in a boot or a hole in the cooler. Also check all of your intake manifold bolts, even if they are tight that does not mean a gasket did not blow out of the manifold.
Rick
Old Jan 29, 2012 | 11:52 AM
dieseldaves
Rick
Rick- followed your suggestions and checked the intake manifold bolts. The rear most bolts were hand tight at best. Needless to say, this fixed the issue. Thanks...
Old Jan 30, 2012 | 09:37 AM
rickf1985's Avatar
rickf1985
You probably have a bit more power now.
Rick
