weird sounds at cold idle
Old Feb 13, 2012 | 12:24 AM
sleddicted's Avatar
sleddicted
Default weird sounds at cold idle
Ok, this has been happening for a while now,
I have a 07 3500 ctd
i have noticed that when i start my truck, cold.... and let it idle, it will some make some what weird sounds. I will have to get out a recorder and record it..
but to describe it, my father inlaw, (mechanic) thinks it could be a injector as he has an 06 ctd and it makes the same sound cold, but not as bad.
it will idle normal, but then to me it almost sounds like a quick surge.. he calls it some what of a miss
so, if i was to describe it: this is what it would sound like: ba ba ba ba ba ba ba blap ba ba ba ba ba blapup
lol the ba's being the normal idle. once warm, no problems
sorry for the horrible discription, I have full warranty
let me know
Old Feb 13, 2012 | 11:35 PM
truck42's Avatar
truck42
i have found that the new ctd 98.5+ when cold have a heated intake that cycles when cold started to heat the incoming air it does make a wierd sound like that. it draws more amps than the alternator can put out.
Old Feb 14, 2012 | 06:55 PM
sleddicted's Avatar
sleddicted
I thought about your reply and sat in my truck with the windows down, started it cold, and listened and watched the voltage gauge.
every time the grid heaters cycled, and the voltage, dropped or was raised the trucks idle changed breifly. (every time voltage needle moved) once the heaters stopped the cycle, everything was normal.
thanks
