05 5.9 HO Hard to start, white smoke, rough idle, and more soot than usual
Old May 13, 2012 | 11:56 AM
Haulin12's Avatar
Haulin12
Default 05 5.9 HO Hard to start, white smoke, rough idle, and more soot than usual
I have an 05 5.9 24 valve HO. Lately the starts are getting harder, small amount of white smoke immediately after start, idles rough for a minute. Also, it seems to be producing much more soot than usual. I have been running fuel cleaner and changed the fuel filter. Seems to be leaking fuel out of an injector and loosing pressure in the common rail as a result. As best as I can figure I have a bad injector or two. Truck runs and pulls fine, mpg is a tad bit lower than usual. The start issue is not just when it is cold, its an issue on every start. The truck also has 220,000k and this is the first engine issue. Looking for advice and opinions please.
Also where is the best place to get injectors?
Old May 15, 2012 | 12:58 AM
Brandon lc's Avatar
Brandon lc
You can get injectors from toxic diesel and also it just might need a good tune up
Old May 15, 2012 | 02:05 PM
Jigabop's Avatar
Jigabop
sounds like a cracked injector nozzle. common for CR trucks...
my truck series has weak injection pumps, your truck series has weak injectors.
good excuse to upgrade to some bigger nozzles!
get on cumminsforum.com and do some reading and question asking there. you will get much faster responses and more people there with your year series truck/engine.
