still learning
Old Jun 14, 2012 | 12:15 AM
CRosner's Avatar
CRosner
Default still learning
where is the fuel pressure regulator valve on a 24 valve
Old Jun 14, 2012 | 11:30 AM
Jigabop's Avatar
Jigabop
are we talkin, 2nd gen 24v 3rd gen 24v, 4th gen 24v ??
also there is no fuel pressure regulator valve...stock lift pumps are junk in all of these trucks and should be replaced with an aftermarket 100GPH or higher lift pump. The lift pumps control fuel pressure with a spring inside the pump. airdog, fass, and raptor use a 17psi spring.
