Weird thing happened today
Old Jul 26, 2012 | 08:44 PM
Gnarkill666's Avatar
Gnarkill666
Default Weird thing happened today
Got in my truck and ran up the road and made 2 stops then came back home and when i turned my truck off and took the key out i couldnt help but notice that the ticking noise from the injectors or w/e when the key is in the on position before starting was going and it wouldnt let me lock my truck. i got back in and turned the key to the on position then off and it was still going. so i started the engine and it turned right back off on its own after running for about 1 second, started it again and it was running fine and didnt have a check engine light, turned it off ticking stopped and i was able to lock it lol. anyone ever have or hear of this before?
Old Jul 29, 2012 | 05:38 PM
iwhitne's Avatar
iwhitne
once you have parked the truck, how long do you wait before you shut it off... try to let it idle for at least a minute before shutting down..
Old Jul 30, 2012 | 07:53 PM
Gnarkill666
I usually shut it down pretty quick but its only done it the one time and i got some info from someone else that seemed like a pretty likely suspect. i was told that heavy keyrings could possibly mess with the cylinder and i just put on a thick metal dodge ram key chain onto the keyring a few weeks ago. since the symptoms were like the key was still in the ignition i took the keychain off and have not had it happen again.
